Assembler 2 Vid MP4 en lignes de Cdes
Messagede aazerty » Mar 22 Avr 2014 16:32
Assembler 2 vidéos .mp4 , "IDENTIQUES" , en ligne de commandes .
==== Exemple de fichier batch
@echo on
ffmpeg -y -i "N12_ABCD_1.mp4" -c copy -bsf:v h264_mp4toannexb -f mpegts "N12_ABCD_1.ts"
ffmpeg -y -i "N12_ABCD_2.mp4" -c copy -bsf:v h264_mp4toannexb -f mpegts "N12_ABCD_2.ts"
ffmpeg -y -i concat:"N12_ABCD_1.ts|N12_ABCD_2.ts" -absf aac_adtstoasc -c copy -f mov "N12_ABCD_complet.mp4"
:fin
==== Processus résultant
ffmpeg version N-53284-gd0a34ae Copyright (c) 2000-2013 the FFmpeg developers
  built on May 20 2013 01:02:45 with gcc 4.7.3 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfi
g --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-li
bopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheo
ra --enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264
--enable-libxavs --enable-libxvid --enable-zlib
  libavutil      52. 33.100 / 52. 33.100
  libavcodec     55. 10.101 / 55. 10.101
  libavformat    55.  7.100 / 55.  7.100
  libavdevice    55.  1.100 / 55.  1.100
  libavfilter     3. 68.101 /  3. 68.101
  libswscale      2.  3.100 /  2.  3.100
  libswresample   0. 17.102 /  0. 17.102
  libpostproc    52.  3.100 / 52.  3.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'N12_ABCD_1.mp4':
  Metadata:
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2014-01-07 17:36:10
  Duration: 00:12:52.92, start: 0.000000, bitrate: 458 kb/s
    Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p, 512x304 [SAR 95:92 DAR 40:23], 35
9 kb/s, SAR 33:32 DAR 33:19, 25 fps, 25 tbr, 25k tbn, 50 tbc
    Metadata:
      handler_name    : ABCD_1sur2_track1.h264:fps=25.000#video - Imported with GPAC 0.5.1-DEV-rev4266
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 95 kb/s
    Metadata:
      creation_time   : 2014-01-07 17:36:11
      handler_name    : ABCD_1sur2_track2.aac#audio - Imported with GPAC 0.5.1-DEV-rev4266
Output #0, mpegts, to 'N12_ABCD_1.ts':
  Metadata:
    major_brand     : isom
    minor_version   : 1
    encoder         : Lavf55.7.100
    Stream #0:0(und): Video: h264 (avc1 / 0x31637661), yuv420p, 512x304 [SAR 33:32 DAR 33:19], q=2-31, 359 kb/s, 25 fps,
90k tbn, 25 tbc
    Metadata:
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, 95 kb/s
    Metadata:
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
[adts @ 02fe7020] Encoder did not produce proper pts, making some up.
frame=19323 fps=13442 q=-1.0 Lsize=   49299kB time=00:12:52.92 bitrate= 522.5kbits/s
video:33934kB audio:9056kB subtitle:0 global headers:0kB muxing overhead 14.673274%
Appuyez sur une touche pour continuer...
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'N12_ABCD_2.mp4':
  Metadata:
    major_brand     : isom
    minor_version   : 1
    creation_time   : 2014-01-07 17:30:47
  Duration: 00:13:20.64, start: 0.000000, bitrate: 458 kb/s
    Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p, 512x304 [SAR 95:92 DAR 40:23], 36
0 kb/s, SAR 33:32 DAR 33:19, 25 fps, 25 tbr, 25k tbn, 50 tbc
    Metadata:
      handler_name    : ABCD_2sur2_track1.h264:fps=25.000#video - Imported with GPAC 0.5.1-DEV-rev4266
    Metadata:
      creation_time   : 2014-01-07 17:30:48
      handler_name    : ABCD_2sur2_track2.aac#audio - Imported with GPAC 0.5.1-DEV-rev4266
Output #0, mpegts, to 'N12_ABCD_2.ts':
  Metadata:
    major_brand     : isom
    minor_version   : 1
    Stream #0:0(und): Video: h264 (avc1 / 0x31637661), yuv420p, 512x304 [SAR 33:32 DAR 33:19], q=2-31, 360 kb/s, 25 fps,
90k tbn, 25 tbc
    Metadata:
    Metadata:
Stream mapping:
[adts @ 02dfcac0] Encoder did not produce proper pts, making some up.
frame=20016 fps=12085 q=-1.0 Lsize=   51101kB time=00:13:20.64 bitrate= 522.9kbits/s
video:35187kB audio:9379kB subtitle:0 global headers:0kB muxing overhead 14.663413%
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 24 invités
