Download failed for m6w9-N.C.I.S.-Saison 9 Episode 11
Messagede Dirk-Pitt » Sam 6 Oct 2012 16:03
J'ai l'erreur suivante lorsque je tente de télécharger NCIS Saison 9 Episode 11 :
C:\Documents and Settings\Administrateur>PushD "C:\habiTV\"
C:\habiTV>"C:\habiTV\jre7\bin\java.exe" -cp lib/consoleView.jar;lib/* com.dabi.habitv.tray.TrayLauncher
Waiting for Searching episode for default
Searching episode for canalPlus is starting
Searching episode for m6w9 is starting
Searching episode for canalPlus done
Episode to retreive m6w9-N.C.I.S.-Saison 9 Episode 11
Searching episode for m6w9 done
Waiting for download of m6w9-N.C.I.S.-Saison 9 Episode 11
Download of m6w9-N.C.I.S.-Saison 9 Episode 11 is starting
com.dabi.habitv.framework.plugin.exception.DownloadFailedException: com.dabi.habitv.framework.plugin.exception.ExecutorFailedException
   at com.dabi.habitv.downloader.rtmpdump.RtmpDumpPluginManager.download(RtmpDumpPluginManager.java:43)
   at com.dabi.habitv.provider.m6w9.M6W9PluginManager.download(M6W9PluginManager.java:88)
   at com.dabi.habitv.core.task.DownloadTask.doCall(DownloadTask.java:83)
   at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
   at java.util.concurrent.FutureTask.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
Caused by: com.dabi.habitv.framework.plugin.exception.ExecutorFailedException
   at com.dabi.habitv.framework.plugin.utils.CmdExecutor.execute(CmdExecutor.java:65)
   at com.dabi.habitv.downloader.rtmpdump.RtmpDumpPluginManager.download(RtmpDumpPluginManager.java:41)
   ... 8 more
download of N.C.I.S. - Saison 9 Episode 11failed
cmd wasbin\rtmpdump.exe -r "rtmpe://groupemsix.fcod.llnwd.net/a2883/e1/mp4:production/regienum/m6_n-c-i-s-_s9e11_430565_051020122050.mp4?s=1349534078&e=1349620478&h=3f6556f443365e221398cb4ee5b8c06b" -c 1935 -m 10 -o "C:/CapTvTy/Vidéos/N.C.I.S.-Saison_9_Episode_1.mp4.tmp"
RTMPDump v2.5 GIT-2012-03-31 (Handshake 10 support by Xeebo)
(c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL
Connecting ...
WARNING: HandShake: Type mismatch: client sent 6, server answered 10
INFO: Connected...
ERROR: HandleCtrl: Ignoring SWFVerification request, use --swfVfy!
ERROR: Closing connection: NetStream.Failed
Episode failed to retreive m6w9-N.C.I.S.-Saison 9 Episode 11
com.dabi.habitv.framework.plugin.exception.TechnicalException: java.util.concurrent.ExecutionException: com.dabi.habitv.core.task.TaskFailedException: com.dabi.habitv.framework.plugin.exception.DownloadFailedException: com.dabi.habitv.framework.plugin.exception.ExecutorFailedException
   at com.dabi.habitv.core.task.AbstractTask.getResult(AbstractTask.java:66)
   at com.dabi.habitv.core.task.DownloadTask.getResult(DownloadTask.java:18)
   at com.dabi.habitv.core.task.AbstractTask.waitEndOfTreatment(AbstractTask.java:59)
   at com.dabi.habitv.core.task.RetrieveTask.download(RetrieveTask.java:123)
   at com.dabi.habitv.core.task.RetrieveTask.doCall(RetrieveTask.java:76)
Caused by: java.util.concurrent.ExecutionException: com.dabi.habitv.core.task.TaskFailedException: com.dabi.habitv.framework.plugin.exception.DownloadFailedException: com.dabi.habitv.framework.plugin.exception.ExecutorFailedException
   at java.util.concurrent.FutureTask$Sync.innerGet(Unknown Source)
   at java.util.concurrent.FutureTask.get(Unknown Source)
   at com.dabi.habitv.core.task.AbstractTask.getResult(AbstractTask.java:64)
   ... 10 more
Caused by: com.dabi.habitv.core.task.TaskFailedException: com.dabi.habitv.framework.plugin.exception.DownloadFailedException: com.dabi.habitv.framework.plugin.exception.ExecutorFailedException
   ... 5 more
Caused by: com.dabi.habitv.framework.plugin.exception.DownloadFailedException: com.dabi.habitv.framework.plugin.exception.ExecutorFailedException
   ... 5 more
   ... 8 more
C:\habiTV>PopD
Avez vous la même erreur ?
Par avance, merci pour vos réponses.
Atchao, dp.
Dirk-Pitt
Re: Download failed for m6w9-N.C.I.S.-Saison 9 Episode 11
Messagede czmaster » Sam 6 Oct 2012 16:48
Chez moi ça marche, mais j'ai laissé la config de base à priori tu as fait quelque modif :
Dirk-Pitt a écrit:cmd wasbin\rtmpdump.exe -r "rtmpe://groupemsix.fcod.llnwd.net/a2883/e1/mp4:production/regienum/m6_n-c-i-s-_s9e11_430565_051020122050.mp4?s=1349534078&e=1349620478&h=3f6556f443365e221398cb4ee5b8c06b" -c 1935 -m 10 -o "C:/CapTvTy/Vidéos
Peut être que le problème vient du changement de dossier (simple supposition).
Messagede Dirk-Pitt » Sam 6 Oct 2012 17:32
Bonjour et merci pour ta réponse, cela dit j'ai la même chose après désinstallation et réinstallation standard. Cela semble venir de chez moi bien que je n'avais pas eu ce problème précédemment ( voir l'autre sujet ). Attendons de voir ce que va dire dabiboo à propos de l'erreur. Atchao, dp.
Waiting for Grabbing categories for lequipe
Waiting for Grabbing categories for beinsport
Waiting for Grabbing categories for tvSubtitles
Waiting for Grabbing categories for tf1
Waiting for Grabbing categories for arte
Waiting for Grabbing categories for rss
Waiting for Grabbing categories for canalPlus
Waiting for Grabbing categories for pluzz
Waiting for Grabbing categories for m6w9
Grabbing categories for arte...
Grabbing categories for tf1...
Grabbing categories for tvSubtitles...
Grabbing categories for beinsport...
Grabbing categories for beinsport done
Grabbing categories for rss...
Grabbing categories for rss done
Grabbing categories for canalPlus...
Grabbing categories for lequipe...
Grabbing categories for tf1 done
Grabbing categories for pluzz...
Grabbing categories for pluzz done
Grabbing categories for m6w9...
Grabbing categories for arte done
Grabbing categories for tvSubtitles done
Grabbing categories for m6w9 done
Grabbing categories for lequipe done
Grabbing categories for canalPlus done
Creating index for N.C.I.S.
   ... 8 more
cmd wasbin\rtmpdump.exe -r "rtmpe://groupemsix.fcod.llnwd.net/a2883/e1/mp4:production/regienum/m6_n-c-i-s-_s9e11_430565_051020122050.mp4?s=1349540483&e=1349626883&h=07875753874bb2d282cb67469e44085e" -c 1935 -m 10 -o "downloads/N.C.I.S.-Saison_9_Episode_1.mp4.tmp"
Connecting ...
INFO: Connected...
   ... 10 more
   ... 5 more
   ... 5 more
   ... 8 more
Dirk-Pitt
Messagede dabiboo » Sam 6 Oct 2012 19:35
bonjour,
Je ne pense pas que ça vient de la configuration : c'était un problème de l'outil rtmpdump, la commande exécutée :
a fonctionné chez moi.
ça te le fait toujours ? je pense que c'était un problème temporaire : m6 surchargé ou inaccessible.
dabiboo
Messagede Dirk-Pitt » Lun 8 Oct 2012 14:00
Bonjour et merci pour ta réponse, je pense que tu as raison car j'ai essayé plus tard et cela a fonctionné. Désolé pour le dérangement. Atchao, dp.
Dirk-Pitt
Messagede dabiboo » Lun 8 Oct 2012 19:50
dabiboo a écrit:bonjour,
a fonctionnée chez moi.
dabiboo
Messagede aazerty » Lun 8 Oct 2012 20:27
Bonjour :
Pour info : attention aux écritures .
C:/CapTvTy/Vidéos => PAS BON !!!
C:\CapTvTy\Vidéos => BON !!!
Messagede aazerty » Lun 8 Oct 2012 20:50
Bonjour à tous ,
Suite aux infos de dabiboo (merci) , à 19h50 .
Constats :
si on lance le batch , sans indiquer quoi que ce soit , on obtient :
Si , on indique : --swfVfy , on obtient :
ERROR: RTMP_hashSWF: couldn't contact swfurl -c (HTTP error -1)
Il faut impérativement indiquer le player .
Question : pouvez-vous me l'indiquer ?
Messagede dabiboo » Mer 10 Oct 2012 06:23
C'est en téléchargeant quel épisode que tu obtiens cette erreur ?
Je n'ai pas eu besoin de renseigner cette propriété pour les téléchargements m6.
dabiboo
Messagede aazerty » Mer 10 Oct 2012 10:16
@dabiboo :
Mon info est un peu hors sujet .
Je reprenais les données fournies , précédemment par toi le 8 oct :
viewtopic.php?f=35&t=3332&p=17450#p17430
et les utilisais dans un batch .
Retourner vers habiTv
