k3c a écrit :
que donne
pour ton Captvty 2 ?
il me semble que Win 7 eest le minimum, si c'est Windows XP cela ne fonctionne pas
Pour la V2 foireuse :
Code : Tout sélectionner
$ export WINEPREFIX="/home/$USER/.wine/daminus"
$ winecfg /v
002c:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
0090:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type 00000005
00ac:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
00ec:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
00ec:err:commdlg:DllMain failed to create activation context, last error 14001
retour après lancement, ça mouline, une fenêtre "Wine Degguer" s'ouvre et se referme, puis le terminal s’arrête :
$ sh -c "env WINEPREFIX=$HOME/.wine/daminus wine $HOME/Vidéos/captvty/captvty-2/Captvty.exe"
0094:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type 00000005
00b0:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
0024:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
0024:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0120:err:ole:CoGetContextToken apartment not initialised
0024:fixme:virtual:NtFlushProcessWriteBuffers stub
0024:fixme:nls:get_dummy_preferred_ui_language (0x0 0x40c 0031DEF0 00000000 0031DEEC) returning a dummy value (current locale)
0024:fixme:nls:get_dummy_preferred_ui_language (0x0 0x40c 0031DEF0 00EE8BB8 0031DEEC) returning a dummy value (current locale)
0024:fixme:ntdll:EtwRegisterTraceGuidsW register trace class {8e9f5090-2d75-4d03-8a81-e5afbf85daf1}
0024:fixme:advapi:RegisterEventSourceW ((null),L".NET Runtime"): stub
0024:fixme:advapi:ReportEventW (CAFE4242,0x0001,0x0000,0x000003ff,00000000,0x0001,0x00000000,0031D5F8,00000000): stub
0024:err:eventlog:ReportEventW L"Application: Captvty.exe\n"
0024:err:eventlog:ReportEventW L"Framework Version: v4.0.30319\n"
0024:err:eventlog:ReportEventW L"Description: The process was terminated due to an internal error in the .NET Runtime at IP 791F55A5 (79140000) with exit code 80131506.\n"
0024:fixme:advapi:DeregisterEventSource (CAFE4242) stub
012c:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
012c:fixme:dbghelp:elf_search_auxv can't find symbol in module
Poour la V2 fonctionnelle à 100%, (même en faisant une copie de mon dossier .wine/captvty-2, sur ma nouvelle machine) :
$ export WINEPREFIX="/home/$USER/.wine/captvty-2"
$ winecfg /v
00a8:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
011c:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
011c:err:commdlg:DllMain failed to create activation context, last error 14001
retour après lancement, ça roule nickel, V2 s'ouvre et est utilisable :
$ sh -c "env WINEPREFIX=$HOME/.wine/captvty-2 wine $HOME/Vidéos/captvty/captvty-2/Captvty.exe"
00a4:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
0118:err:ole:CoGetContextToken apartment not initialised
0024:fixme:nls:get_dummy_preferred_ui_language (0x0 0x40c 0031DEF0 00EE8F78 0031DEEC) returning a dummy value (current locale)
0024:fixme:ras:RasEnumConnectionsW (00F1FDB8,0031F020,0031F024),stub!
0024:fixme:ras:RasEnumConnectionsW RAS support is not implemented! Configure program to use LAN connection/winsock instead!
0024:fixme:ras:RasConnectionNotificationW (FFFFFFFF,000001EC,0x00000003),stub!
0024:fixme:mlang:GetGlobalFontLinkObject 0031DBD0: stub
0024:fixme:mlang:GetGlobalFontLinkObject 0031E0B4: stub
0024:fixme:mlang:GetGlobalFontLinkObject 0031DD50: stub
0024:fixme:mlang:GetGlobalFontLinkObject 0031DD60: stub
0024:fixme:mlang:GetGlobalFontLinkObject 0031E8E0: stub
Pour les versions Winedaube, que ce soit winXP ou win7, les 2 fonctionnent.
Sinon, dans le cas présent, voici ma config d'installe, celle de base, une vieille... :
$ export WINEARCH=win32 winecfg
$ winetricks -q dotnet40_kb2468871 gdiplus comctl32 corefonts ie8 vcrun2008 vlc
Sachant que celle-ci aussi fonctionne, je fais tourner V2 & V3 Alpha en 32bit :
Mais la aussi une ré-installation propre est impossible, BUG !!
$ export WINEPREFIX="/home/$USER/.wine/captvty"
$ winetricks -q dotnet452 gdiplus comctl32 corefonts ie8 vcrun2008 vcrun2010 vlc
Et pour finir le 'cabextract du 'gdiplus' est inutile, depuis 2018 ça doit etre prit en compte par 'winetricks' (en tous cas je ne l'ai jamais fais)
Tout comme le winetricks 'ie8' (mais les habitudes, c'est dur à changer...) un winetricks 'msls31' serait surement suffisant, à tester...
Linux 64 bits / France / Firefox 122.0
